Group: DynoMotion Message: 5719 From: somethingfree123 Date: 9/30/2012
Subject: Getting started with tool setup
I've just started setting up my Kflop. I've been using DeltaTau in the past and might I say how much EASIER and more intuitive this is to setup!! Not to mention the documentation is much more straight forward.
Anyways, to the point: I am setting up the M-codes in the Tool Setup and have a question.
I set up M3 to set bit 144, M4 to set bit 145 and M6 to reset both.
After setting it up I step through the Gcode (See below). Then, I view the outputs in Kmotion hoping to see 144 have a check next to it. But, nothing happens.
I am sure it's an easy issue but have been banging my head against it for quite a while tonight.
Any help is much appreciated,
RB
My test Gcode
G90 G21
M03
M04
M05
M02
Group: DynoMotion Message: 5720 From: tmday7 Date: 9/30/2012
Subject: Re: Getting started with tool setup
Hello,
I have only used KmotionCNC very little as i use Mach3, but did you mean to say bit 44 and bit 45 instead of 144 and 145?
Troy
--- In DynoMotion@yahoogroups.com, "somethingfree123" wrote:
> Hi,
> RB
> My test Gcode
> G90 G21
> M03
> M04
> M05
> M02
Group: DynoMotion Message: 5721 From: Michael Rosenfield Date: 9/30/2012
I am doing a similar thing; I would say that you need to have M3 set 144 AND clear 145; M4 set 145 AND clear 144, and M5 (not M6) clear both. This works for me.
Michael Rosenfield
Group: DynoMotion Message: 5722 From: somethingfree123 Date: 10/1/2012
I have a KAnalog board. So, I'm using the isolated outputs for these functions.
A related question would be, why use Mach3? What are the benefits of going through the trouble to set all that up instead of using KmotionCNC?
--- In DynoMotion@yahoogroups.com, "tmday7" <brotroy7@...> wrote:
> Hello,
> Troy
> > Hi,
> > RB
> > My test Gcode
> > G90 G21
> > M03
> > M04
> > M05
> > M02
Group: DynoMotion Message: 5723 From: somethingfree123 Date: 10/1/2012
That's a good call. Thanks for the info. I am still having trouble actually triggering the outputs. Even when I set/clear bits I don't see a check mark show up next to 144 or 145 in the Discrete IO status window.
Ryan
--- In DynoMotion@yahoogroups.com, Michael Rosenfield <mrosenfield@...> wrote:
> I am doing a similar thing; I would say that you need to have M3 set 144 AND clear 145; M4 set 145 AND clear 144, and M5 (not M6) clear both. This works for me. Michael Rosenfield
> From: brotroy7@...
> Date: Mon, 1 Oct 2012 02:23:51 +0000
> Subject: [DynoMotion] Re: Getting started with tool setup
> Hello,
> Troy
> > Hi,
> > RB
> > My test Gcode
> > G90 G21
> > M03
> > M04
> > M05
> > M02
Group: DynoMotion Message: 5724 From: tmday7 Date: 10/1/2012
Ahh, ok. :)
I started out using Mach3 at the time i found KFLOP. So it was easier for me to just keep using it and at the time KmotionCNC was not easily customizable. But i believe Brad has something in the works that will make KmotionCNC or WebNC as it was called, just as nice. :)
Thats what iam waiting on.
Keep in mind that Kmotion uses a much better Trajectory Planner than the current Mach3. But as i hear it Mach4 will have a much better planner then Mach3.
Anyhow,
Troy
--- In DynoMotion@yahoogroups.com, "somethingfree123" <somethingfree123@...> wrote:
> --- In DynoMotion@yahoogroups.com, "tmday7" <brotroy7@> wrote:
> > Hello,
> > Troy
> > > Hi,
> > > RB
> > > My test Gcode
> > > G90 G21
> > > M03
> > > M04
> > > M05
> > > M02
Group: DynoMotion Message: 5726 From: Tom Kerekes Date: 10/1/2012
Hi Ryan,
That should work.  I just tested it.  Maybe post a screen shot of your Tool Setup | M3-M9 screen.
Is the Kanalog charge pump LED on?
What Version are you using?
Sent: Sunday, September 30, 2012 4:05 PM
Subject: [DynoMotion] Getting started with tool setup
RB
My test Gcode
G90 G21
M03
M04
M05
M02
Group: DynoMotion Message: 5900 From: somethingfree123 Date: 10/25/2012
Ok, I'm back to work on the project. Still can't get M codes to write to outputs. But, I can operate outputs via the buttons.
It should be noted that I don't have any axis set up yet. Not sure if that should matter.
I am able to set the spindle speed with the S # code.
I'm not sure how to attach a picture to my post but my setup looks just like the example except that I am using 144 and 145 for my outputs on Kanalog.
Ryan
> Hi Ryan,
> From: somethingfree123 <somethingfree123@...>
> Hi,
> RB
> My test Gcode
> G90 G21
> M03
> M04
> M05
> M02
Group: DynoMotion Message: 5906 From: Tom Kerekes Date: 10/26/2012
Hi Ryan,
You didn't answer my questions.  But actually there is a known issue with MCode Bit commands in V4.29 when used by themselves (without any motion) and the Low Pass Coordinated Motion Filtering (KLP in the C Code) enabled.
Please try the latest Test release and see if you still have a problem:
Group: DynoMotion Message: 7885 From: mait.reidak Date: 7/9/2013
I have similar problem, didn't want to start a new thread.
I use virtual bits (1025, 1026, 1027) and RS232 to control trough Arduino some external outputs: solid state relays for spindle, flood coolant pump and stepper motors PSU. PSU is currently uncontrolled, just the virtual bit is switched high in init.c .
With User Buttons in KmotionCNC, I am able to control all without problems but codes M3 and M8 are not working.
Version info from console:
KFLOP 4.30 Build 12:02:08 Mar 3 2013
Help - About of KMotion shows 4.30 as well.
Mait
Group: DynoMotion Message: 7890 From: Tom Kerekes Date: 7/9/2013
Hi Mait,
Buffered IO commands were limited to IO numbers less than 256.
Here is a patch that can be applied to test Version 4.31f that should allow numbers to 2047.
http://dynomotion.com/Software/Patch/AllowSetBitBuf1024V431f/DSPKFLOP.out
http://dynomotion.com/Software/Patch/AllowSetBitBuf1024V431f/KMotionDef.h
http://dynomotion.com/Software/KMotion431f.exe
Group: DynoMotion Message: 7894 From: mait.reidak Date: 7/9/2013
Thanks a lot, that helped.
Mait
Group: DynoMotion Message: 7896 From: mait.reidak Date: 7/10/2013
Well, helped sort-of.
Now it starts M3 and M8 but stopping is another issue.
So far I have been able to test only a little but I hope it helps to find the problem:
Starting spindle/coolant (M3, M8); making some simple moves (G0, G1) and stopping spindle/coolant (M5, M9) and ending program (M2) - everything works as it should.
But when using drilling cycles, either G81 or G83, after that M5/M9 wont stop spindle/coolant. Toggling proper virtual bits from console or passing commands directly from code (CMD, xxx) still works (so do user buttons).
Mait.
PS: The new hotkey assigment to user buttons is great but using "hardcoded" hotkeys like F5 or Esc - is not that good. Fortunately nothing is broken :)
--- In DynoMotion@yahoogroups.com, "mait.reidak" <mait.reidak@...> wrote:
> Hi,
> Mait
Group: DynoMotion Message: 7897 From: Tom Kerekes Date: 7/10/2013
Hi Mait,
I can't duplicate the problem.  This works ok for me where M3 is configured for bit 1024 and M8 for 1025
M3
M8
G20 G0 X0 Y0 Z0 F12
G81 X4 Y5 Z1.5 R2.8
M5
M9
M2
Please send an example.
Group: DynoMotion Message: 7898 From: mait.reidak Date: 7/10/2013
For me, the example you provided, is not switching off neither spindle or coolant.
If I delete the G81 ... line, everything works fine.
Checked the 1025/1026 bits I use, both remain high after M5/M9/M2
I tried to switch back to default configuration (restored the C:\KMotion431f\KMotion\Data directory I replaced when upgrading to 4.31f version), still no effect.
> Hi Mait,
> M3
> M8
> G20 G0 X0 Y0 Z0 F12
> G81 X4 Y5 Z1.5 R2.8
> M5
> M9
> M2
Group: DynoMotion Message: 7906 From: Tom Kerekes Date: 7/10/2013
Hi Mait,
I don't know.  Maybe I forgot to include something in the patch.  Here is a complete Test Version.  Please try it.  I tested the GCode and it works ok.
http://dynomotion.com/Software/KMotion431g.exe
Group: DynoMotion Message: 7908 From: mait.reidak Date: 7/11/2013
As far I can tell, this fixed the problem. The sample you provided works as it should.
Thank you.
Mait
> Hi Mait,
